Posted by JM in Merit on May 30, 2009 at 18:54:35 from (12.39.109.74):
540 pto shaft is leaking, looks like seal is missing, not sure what happened to it. Is the seal on the 1000 output shaft the same as the 540? Also it appears that you can put the seal on with out removing pto, is that correct or do you have to remove PTO unit? anyone know where you can find one on a Sunday? trying to get hay baled before Monday.Any ideas to get by for about 2 to 3 hours of running time beside just adding oil and more oil. The 540 shaft also has movement in and out but no top to bottom movement on the shaft, where as the 1000 shaft has no movement any place, is this a problem Thanks
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
