Posted by Janicholson on May 30, 2009 at 19:50:10 from (66.173.50.139):
In Reply to: dry plugs? posted by DozerD on May 30, 2009 at 18:54:55:
Prime the cylinders with a teaspoon of gasoline each. If it briefly starts, you will then know it is a fuel delivery issue. Vacuum leaks At the manifold are possible, as is passages in the carb plugged up. If it starts then dies, try holding your hand over the intake of the carb when cranking. if it sucks your hand enough to make you pull it away, it probably needs passages cleaned in the carb. JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
