Which oil filter, pressue regulating base do you have. Did you repair or replace the springs and valve. We used to have a lot of problems with these pot medal filter bases and the valves in them. Early ones had a fiber disc which was very poor, and then they went to a medal one but you still had to be sure the seat was good. They also made stronger spring, and you should run about 40 psi at high rpms. Older model engines like on the 560 used a cast iron base with a plunger type relief valve and were much less problem. It a lot easier to check this item first but of course pump or other problems could exist.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
