Re: 656 Low Oil Pressure after rebuild (like CJ 1080)
Posted by pete 23 on May 30, 2009 at 20:35:22 from (173.87.14.132):
In Reply to: 656 Low Oil Pressure after rebuild (like CJ 1080) posted by TX656 on May 30, 2009 at 19:54:58:
What I am talking about is , under the spring there is a valve. You need to take the snap ring out that holds the spring in housing and check that valve is making a leak proof seat in housing. The valve may be a fiber disc or a metal one. It will be obvious to the naked eye if seat is good or not. Also, make darn sure gasket matches base as there are at least three different configuration of gaskets that usually come in a gasket kit. I just looked at the online parts book on CaseIH and they showed only the pot metal type filter base for a 656 so I am 99 percent sure that is what you have. A worn oil pump will usually give you pretty good pressure when cold but a leaking or weak regulator valve will not. Another thing, you need to make sure correct spring is installed on regulator as the other spring is a filter bypass valve and much weaker. Known correct gauge also of course. If you haven't, take a look at the parts manuals available on CaseIh site, for model you need to put in C-263 as the engine manual is seperate from rest of tractor .
