[quote="chuck's Repair"](quoted from post at 23:17:21 05/30/09) Pull the oil pan and pressure lube the system.
To do that I'm guessing I need to do one of the following:
"Plan A"
1) drop the pan,
2) pull the plugs
3) immerse the pickup in a pail/pan/bucket of oil
4) have someone crank over the engine while I watch underneath
"Plan B"
a) drop the pan
b) pull the pump
c) use something to force oil into where the oil pump bolted to the bottom of the block? What are some good ways/tools to do that? I don't have a pre-luber.
How much 'return' oil should I expect to be ready to have draining back and from where? I guess I can catch the return oil in one of those concrete mixing tubs from the lumber store?
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
