Re: 656 Low Oil Pressure after rebuild (like CJ 1080)
Posted by El Toro on May 31, 2009 at 03:58:50 from (205.188.116.73):
In Reply to: 656 Low Oil Pressure after rebuild (like CJ 1080) posted by TX656 on May 30, 2009 at 19:54:58:
You should have used engine oil or lubri-plate
on the bearings. I would run straight 30 wt oil in the summer and see if that helps. Hal
