Re: 656 Low Oil Pressure after rebuild (like CJ 1080)
Posted by teddy52food on May 31, 2009 at 07:22:43 from (209.237.111.169):
In Reply to: 656 Low Oil Pressure after rebuild (like CJ 1080) posted by TX656 on May 30, 2009 at 19:54:58:
I would try another gauge first. Did you plastigage the bearings? If the crank had been ground and you now put std bearings in it, you will have low pressure.
