Posted by Armand Tatro on May 31, 2009 at 07:31:12 from (71.239.10.80):
In Reply to: Overdrive on a M posted by BSpauld on May 31, 2009 at 05:24:25:
If that overdrive has a cable shift linkage the cable could be broke or disconected internally. If mechanical linkage first place to look is where shaft comes out of the trans. housing. The lever that attatches to that shaft could be loose on the shaft. Also as was stated could be stuck cable if cable linkage. To free-up cable use lots of Break-a-way. Armand
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
