Posted by Armand Tatro on May 31, 2009 at 07:39:04 from (71.239.10.80):
In Reply to: Overdrive on a M posted by BSpauld on May 31, 2009 at 05:24:25:
Take the belt pulley off(if it has one or the delete cover if no belt pulley) and there will be another cover to take off. Also remove the operators deck to see inside the trans. Than split tractor only if needed. Let us know what you find. Armand
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
