Posted by John T on May 31, 2009 at 09:15:05 from (66.244.97.31):
In Reply to: 53 Super A not starting posted by Adrian Billheimer on May 31, 2009 at 08:58:16:
I'd be "looking at" a good battery charge the first thing, that may be allllllll she needs. If the points arent burned or carboned over they may be okay. Of course, leaving the ignition on may have overheated n harmed the coil, the other Id be "looking at" would be to see if the coils primary (between its lil + and - terminals) still has continuity (not burned open). An ohmmeter should show around 1.25 to under 2 ohms if its a 6 volt coil,,,,,,,,,of course, if it reads an open circuit its badddddddd..
Put a test pamp on the coils input (from ign switch) n turn her on and a test lamp or voltmeter should read hot voltage. Then place it over on the output (to distributor) terminal and there should be near zero volts when points are closed but hot battery voltage when points are open UNLESS the coils primary is burned open
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
