Re: trans rear gear oil levels famall A 1942
Posted by Red Dave on May 31, 2009 at 11:05:08 from (98.235.15.235):
In Reply to: trans rear gear oil levels famall A 1942 posted by weisslakerancher on May 31, 2009 at 10:12:22:
Transmission oil level is checked at a the plug on the left-hand side of the transmission, toward the front of it. The plug will be almost hidden by the left-side brake rod. If you take the plug out and a little oil seeps out, it is OK.
There is no separate level check for the PTO, it shares oil with the transmission.
The final drive oil level is checked at a plug on the inside of the drive, toward the front, just above the oil pan. It takes a square 1/2" or 9/16" plug to remove it, I usually use a 1/2" drive socket extension. It is also where you add oil to the final drive.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
