Just thought of something else. I wonder if the filter base doesn't cover one of the oil gallery 1/8 inch pipe plugs also. If that plug was left out you would lose a lot of oil. Also, if you still have the fiber valve with a hole in it , get rid of it . That hole originally had a loose rivet in it, don't ask me why, but that is the filter bypass valve provided it is installed in the correct position and if not, that could also be a place for alot of oil to escape regulating valve. That should have been taken out 30 plus years ago, and then I would put in the steel valves and new pressure regulating spring. Make doubly sure the correct spring is installed in correct place.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
