Re: antiseize comp'd on tire beads
Posted by Dr. Bert on May 31, 2009 at 20:10:45 from (72.36.57.58):
In Reply to: Re: antiseize comp'd on tire beads posted by John G. Hasler on May 31, 2009 at 19:36:38:
John: Thanks for the heads-up. I'll keep looking--hope to find something that will last longer than tire soap. Why do tires always go flat on weekends when the shops are closed?
