Re: antiseize comp'd on tire beads
Posted by Janicholson on May 31, 2009 at 20:55:53 from (66.173.50.46):
In Reply to: antiseize comp'd on tire beads posted by Dr. Bert on May 31, 2009 at 19:29:28:
Even if you found a non petroleum based antisieze, the tire would turn on the rim ripping the stem, and ruining the tire. A main ingredient is the physical connection between the rim and the tire.
Difficulty bead braking is SOP. JimN
