Re: Farmall M Governor Problem
Posted by ih560 on May 31, 2009 at 22:22:02 from (67.131.50.233):
In Reply to: Farmall M Governor Problem posted by TractormanNC on May 31, 2009 at 18:25:49:
TractormanNC said: (quoted from post at 18:25:49 05/31/09) Sticky or binding linkage between gov and carb. Gov to carb linkage not synchronized correctly. worn out rotating assembly in gov.
The only thing that gets me, if it was just sticking or binding linkage then when I took my finger and pushed it back to idle it should stay there, but it goes back to 1000 RPMs as soon as I let pressure off of the arm inside of the governor, even though the spring has no tension on it.
