Re: H front dust seals and fan
Posted by farmalldanzil on June 01, 2009 at 11:23:38 from (72.215.0.62):
In Reply to: H front dust seals and fan posted by stephen toth on June 01, 2009 at 10:48:11:
remove the drive pin from pump driver (dog bone) and it should come off. Dust shield is on the bottom of all the bearing and such, remove tha hub cap- then bearing retainer nut, from there it should all come off. clean and pack the bearings back on--dust shield,bearing spacer,felt washer,oil seal,bearing cone,bearing cup,felt washer retainer,grease retainer,wheel,grease retainer,bearing cap,bearing cone,bearing retainer washer,retainer nut,hub cap. hope that helps dan.
