Re: Farmall C grinding gears
Posted by ScottyHOMEy on June 01, 2009 at 13:39:45 from (71.241.217.155):
In Reply to: Farmall C grinding gears posted by Eric Phipps on June 01, 2009 at 13:23:21:
They all clash some, the nature of the beast. Easiest first recommendation is to count off three or four seconds after depressing teh clutch pedal and see if that cuts down on it -- gives the input shaft time to spin down to a stop after the clutch is released. Could be too much free play in the clutch pedal, but just as or more likely a dirty pilot bushing.
Checking and adjusting free play is easy if that's what it needs. The arm of the pedal should be 1-7/16" in front of the edge of the top deck when you begin to feel the tension of the bearing hitting the clutch fingers. The adjustment is by turning teh clevis on the rod that connects the pedal arms to the short arm on the torque.
If that's all in adjustment, next most likely is the pilot bushing. Test for that needs a helper. With clutch pedal properly adjusted, the motor running at or near idle, drive train in neutral, PTO in gear and the clutch disengaged, see if the PTO shaft is turning. If it is, it's likely the pilot bushing. Engage the clutch so that the PTO should be turning anyway, then throw the clutch back out and see how long it takes to stop. If tow or three seconds everything's probably fine. If it keeps turning with clutch released, it'll most likey be the pilot bushing.
