IH1066 and JD530 baler - PTO shaft
Posted by Michael Sheik on June 02, 2009 at 04:40:56 from (199.153.192.254):
When I hook up the baler to this tractor, I have to put the drawbar in stow position to get close to the required measurement from the end of the PTO shaft(1000 rpm) to center of drawbar pin hole. JD says 14 inches then you add on the hitch attachment for the baler. Well that was a little short and caused some binding. Putting the hitch in the ohter position makes the hitch too long and only about an inch of the PTO tubes contacting. I could machine a new hole in drawbar between the stow and work positions or shorten the bolt-on hitch that goes with the baler. Can someone tell me best option and how much you can extend the tube before it is too much.
