Re: Super A regulator
Posted by Fred Miller on June 02, 2009 at 05:22:08 from (71.254.24.226):
In Reply to: Re: Super A regulator posted by John T on June 02, 2009 at 04:17:06:
Hi Guys,
Thanks for all the good input! I am suspect of the ground on my voltage regulator so I going to go jump it to ground and see what happens.
I rebuilt the generator and hooked the brushes back up the way they were. Does it matter which brush goes to the arm and which to the field?
Thanks again,
Fred
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
