Re: carb settings for jets on 1947 farmall H
Posted by rustyfarmall on June 02, 2009 at 05:36:33 from (209.152.78.140):
In Reply to: carb settings for jets on 1947 farmall H posted by DLove on June 02, 2009 at 05:25:27:
Fuel is getting TO the carb., but is the fuel getting INTO the carb?
Take it apart, remove and clean the float valve with spray carb cleaner, blow it dry with compressed air and reassemble. Double check the float height setting and also that the float moves freely.
I guess that IF the load adjustment screw is turned all the way in, which it should NOT be, then NO fuel can get into the main stem, and the tractor will not run.
The load screw should be set at 3 turns out (factory initial setting), and the idle/air adjustment screw should be set a 1 1/2 turns out (factory initial setting)
