Re: H Gas Tank
Posted by rustyfarmall on June 02, 2009 at 10:49:36 from (209.152.78.140):
In Reply to: H Gas Tank posted by Tommy D6-8U on June 02, 2009 at 09:20:22:
The kerosene/distillate tractors DID have the sediment bowl installed under the starting tank, but that sediment bowl had two (2) outlets, or inlets, whatever you want to call them. One inlet was connected directly the main (large) fuel tank, and the second outlet fed a fuel line that went to the carburetor, so when the tractor was running, the distillate fuel from the main tank went first to the sediment bowl under the starting tank, and then it fed the carburetor.
