Posted by rustyfarmall on June 02, 2009 at 10:58:04 from (209.152.78.140):
In Reply to: Lift-All Problem posted by Dave From Texas on June 02, 2009 at 08:54:02:
The type of oil in the pump is not real critical on these older systems, but the quantity IS critical, so like the other guy said, make sure there is enough oil in the reservoir.
Also, I remember several years back using an H to plant corn with a 4 row planter. The lift-all had been working perfectly for about 40 acres, and then suddenly just refused to lift the planter. I dropped the pump out of the tractor, took it to a neighbor who did mechanic work, and he opened it up, removed a shim or two from the pump mechanism, put it back together and the pump worked just fine again.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
