Re: Farmall H engine knock
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Greg L. Martin on April 12, 2000 at 11:23:50 from (216.128.162.107):
In Reply to: Farmall H engine knock posted by Ron on April 11, 2000 at 19:38:53:
I should of said this when I was explaining knocks, if you have a rod or main bearing out, there will be a fine line of bearing material slung on the sides of the block on the inside of the crankcase.
I would still put the pan back on and isolate the noise before I started pulling rod and main caps off [ unless I could shake or visually see something wrong in the pan], more than likely if you pull a rod cap you will see it worn to the backing material anyhow.
Email if I can help, I will be away from the site till Sat morning, time to go make my living, I just love working 2 1/2 days a week, gives me time to play with my farmalls////,
Post A Followup
: Re: Re: Farmall H engine knock
