Re: Farmall A Mower
Posted by TWheat on June 02, 2009 at 13:50:50 from (76.3.172.45):
In Reply to: Farmall A Mower posted by Zach Bouchard on June 02, 2009 at 10:09:21:
Zack, Scotty, I think the A/C 21 does have a lot of commonality parts. The attachment to the tractor on the C/21./ 22 would be different for sure. Zack, I have a couple of rear mounted mowers,(no parts manual) what parts are refering to?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
