Posted by karl f on June 02, 2009 at 14:25:25 from (209.188.106.159):
In Reply to: 666 Brake Lock Up posted by Lance_MF_180 on June 02, 2009 at 13:06:31:
did you check for play on the pinion shafts? (the same shafts the brake disks engage) Having wheel lock up problems on our 656, with what sounded like brakes engaging randomly, turns out the pinion shaft bearing is out on one side and possibly the needle bearing it passes through in the differential case. also dependig how far you dissassemble and which parts you replace, you may need to measure and reshim for bearing play karl f
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
