Re: IH 3414 Power steering- pressure loading up?
Posted by Roy Ward on June 02, 2009 at 15:34:02 from (66.82.9.83):
In Reply to: IH 3414 Power steering- pressure loading up? posted by Holefix on June 02, 2009 at 09:16:18:
There is a flow divider between the input to the steering and the loader. That may be the problem.
I also believe there is a manual valve you use to change the steering and the loader over to the backhoe swing. If I am right in my thinking on your 3414 you have a engine mount pump that supplies the steering,loader and swing. Then you have a pump mounted on the crank shaft that supplies the other backhoe functions. I would start with the divider.
