While the C-301 is a non-sleeve engine, to say it CAN'T be sleeved is doing a disservice to your QUALIFIED machine shop. Pappy had a customer who picked up an 806 that was a bit weak. After tearing the engine down, Pappy found the engine was already bored .030 oversize, the largest he could get pistons to fit. So he sent the block to Atlas Machine in Louisville, KY and had the block sleeved back to standard bore. After building the engine back to stock specs, it was still running the last I heard a couple of years ago. BTW, Pappy died in 1991...so that 806 had to have been built in '89 or '90.
So the block on the C-301 CAN be sleeved back to stock...it's just something you can't do in the shed out back, you have to have it bored and sleeved at a machine shop.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
