Re: 666 Brake Lock Up
Posted by pete 23 on June 03, 2009 at 10:29:10 from (173.87.14.132):
In Reply to: 666 Brake Lock Up posted by Lance_MF_180 on June 02, 2009 at 13:06:31:
Will add kind of a late comment here. Provided all parts are in good shape and shimmed properly, you can start to think about the quality of the brake discs. Has been a real problem since the use of asbestos has been restricted. The last discs I used from CaseIH worked well. Earlier ones did not. Had problems on the case tractors also. A little off subject, but the old caravan my son gave me because it needed a new fuel pump and he didn't want to spend any money on it with over 200 K miles, well, it developed a rear brake problem, broke a spring and as linings were worn out, I put in a cheap set of shoes. I took them drums off about 3 or four times to make sure things were ok, polished up the drums and linings etc. It would lock up a wheel with a touch of the pedal. I took them shoes out, put in another pair of better quality and have about another 30 K on them. Lot of difference in lining materials.
