Re: Fertilizer Chain
Posted by Bob on June 03, 2009 at 10:37:04 from (69.178.228.68):
In Reply to: Fertilizer Chain posted by SaTom on June 03, 2009 at 09:26:21:
Here's how it was done more easily "back in the day":
Item labeled 613 (Q-5027) in the photo is a "steel chain breaker".
You inserted a link in the slot of the appropriate size for the chain you are working with, then align the slot in the link you are removing with the the adjoined link, then tap them apart with a hammer.
