Re: farmall 400 shifting problems
Posted by Janicholson on June 03, 2009 at 19:24:14 from (66.173.50.20):
In Reply to: farmall 400 shifting problems posted by f826 on June 03, 2009 at 19:12:03:
The TA has mass, as it spins it tends to stay spinning. TA back reduces the spindown time. The others may have thicker trans oil, or less mass.
My uncles 400 was the same. JimN
