Posted by Paul in Mich on June 04, 2009 at 03:09:29 from (66.188.15.68):
In Reply to: turning tires around posted by farmallsm on June 03, 2009 at 22:53:50:
Drive tires are generally mounted with the tread pointing upward when viewed from the rear, because they unload from center to outside of the tread in soft or sticky ground, as opposed to the dirt simply building up, and pushing toward the center. Driven tire such as combine 2WD rear tires act just the opposite so they are mounted with the tread pointing downward when viewed from the rear. However, Combines with 4WD will have the rear tires mounted the same as the fronts with treads facing in the same direction, all for the same reasons.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
