Re: F20 Gasoline tank.
Posted by GordoSD on June 04, 2009 at 05:04:52 from (66.115.200.140):
In Reply to: F20 Gasoline tank. posted by dej(jed) on June 04, 2009 at 04:20:29:
The front section is the main tank. The rear is the "reserve" tank. Always operate the tractor with the valve on the sediment bowl closed, and when you run out of gas in the main tank, then open that valve to switch to reserve.
The "lid" behind the steering post is a reserve water tank for the radiator, Fill it to the top with water.
HTH
Gordo
