Re: 12V Conversion on IH Utilitty 340
Posted by Catskill Pete on June 04, 2009 at 18:17:29 from (209.23.11.6):
In Reply to: 12V Conversion on IH Utilitty 340 posted by Mac DeBusk on June 04, 2009 at 05:14:57:
Easy to install,sounds a little weird, but works. Install the alternator upside down. The narrow alt. ear is now the bottom pivot. The wide ear attaches to the top bracket. That solves the belt alignment issue. You might need a washer or two on the bottom bolt to get perfect alignment on the belt,but its very close.
On the top bracket I had use a 3 inch piece of flat stock mounted straight up on the original bracket bolt in the engine Then drilled a hole in the top of the flat stock to attach the original mounting bracket to that. That gives you elevation on the top bracket to deal with the larger diameter body of the alt. Sorry I can"t supply a picture.[dead camera] but mine has been mounted on my 340U for 20 years like that,trouble free. Note: this is with a 10si, I am not sure a 12si will work quite the same.
