Assuming you have the engine-driven pump, and the factory "christmas tree" valve here's how the hoses go. It's really quite simple. You work in complete loops. The easiest thing to do is put the second valve in the loop first:
Loop #1:
1. From the pressure side of the pump to the second valve IN port.
2. From the OUT port of the second valve to the IN port of the factory valve.
3. Out the bottom of the factory valve back to the fill pipe of the reservoir.
4. From the drain port on the reservoir to the suction side of the pump.
Loop #2:
1. From one WORK port on the factory valve to a T fitting.
2. From each leg of the T fitting to the bottom ports of the lift cylinders.
3. From the top ports of the lift cylinders to a second T fitting.
4. From the second T fitting back to the other WORK port on the factory valve.
Loop #3:
1. From one WORK port on the second valve to a T fitting.
2. From each leg of the T fitting to the bottom ports of the bucket cylinders.
3. From the top ports of the bucket cylinders to a second T fitting.
4. From the second T fitting back to the other WORK port on the second valve.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
