Re: super c cam gear not good!!!!!!!!!
Posted by Bob M on June 05, 2009 at 07:32:55 from (151.190.254.108):
In Reply to: Re: super c cam gear not good!!!!!!!!! posted by beer on June 05, 2009 at 06:36:55:
I agree with JimN - very likely the relief valve is either set too high or is inoperative.
I'm not familiar with the Super C nor its relief valve location, psi setting and adjustment. However if there's any question about the existing valve suggest installing new, independent relief valve plumbed into the pressure line immediately downstream from the pump. Set the new valve no higher than the design pressure spec'd in the SC owner's manual.
