Re: Re: can't start my TD-9 on gasoline - suggestions?
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Loren Pribyl on April 12, 2000 at 16:56:44 from (209.105.50.151):
In Reply to: Re: can't start my TD-9 on gasoline - suggestions? posted by Roger on April 10, 2000 at 19:46:35:
Roger,
Did you happen to notice how much free movement of the rotor there was on your MD dist.? When I took off the dist. cap, I noticed that I can rotate the rotor several degrees either way. Is this normal due to the advance mechanism in the distributor, or is something messed up? I have the plug wires connected as you described (CCW). #1 wire is toward engine block, as indicated by 1 on the cap. Just for curiosity, I moved the wires all back one position (#1 cyl. on #2 cap terminal), and it backfired once, so it looks like the wires are on right.
Post A Followup
: Re: Re: Re: can't start my TD-9 on gasoline - suggestions?
