sputtering 560 gas---help
Posted by bigkahuna on June 05, 2009 at 08:41:36 from (24.118.174.197):
have changed: points, condenser, coil, oil, plugs, gas line and tank clean, carb is clean. when tractor has been driven .5 hour and is warm. the tractor will act like it is getting no fuel. open throttle wide open and pull choke out and motor will re and then almost die and then rev again. this goes on for awhile then the motor almost sounds like a cough and then t will run smooth for awhile until this process happens again. which varies time wise. any assistence will be much appreciatd
