Re: Mag or Carb?
Posted by rustyfarmall on June 05, 2009 at 11:16:34 from (209.152.78.140):
In Reply to: Mag or Carb? posted by Steve W (NY) on June 05, 2009 at 11:13:19:
Yes, and the Magman is right up there in your neck of the woods.
Also, be very stingy with that choke rod. These old Farmalls just plain don't require much choking.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
