Re: super c pressure relief
Posted by Bob M on June 05, 2009 at 13:32:02 from (151.190.254.108):
In Reply to: super c pressure relief posted by beer on June 05, 2009 at 13:18:40:
Per the exploded view in the I&T manual the pump has no integral relief valve. The touch control diagram however shows both a "safety valve" and a "pressure regulator valve". They are located together behind the cylinder head plate on the touch control housing.
Not sure the difference between the two valves - the text in the manual is pretty sparse. However I'd guess from the diagram the "safety valve" is the system pressure relief.
Unfortunately neither valve appears to be adjustable.
