Re: super c pressure relief
Posted by beer on June 05, 2009 at 14:06:30 from (66.159.152.196):
In Reply to: super c pressure relief posted by beer on June 05, 2009 at 13:18:40:
I have all the books and the touch control is rebuilt. The problem I have is the pump stripped the teeth off my cam gear.When I was using the loader. this tractor also has a fasthitch.The way I plumbed the loader is the valve for the fast hitch I took the hoses off and Installed T's then 2 ball valves on each T. So if 2 valves are open the fasthitch works, Then close those open the other 2 and the loader works.I thought I was pressure protected because ther is no pressure relief on fasthitch
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
