Re: super c pressure relief
Posted by Janicholson on June 05, 2009 at 16:42:04 from (66.173.50.47):
In Reply to: super c pressure relief posted by beer on June 05, 2009 at 13:18:40:
I think (but do not know) that you have tapped into the system between the pump and the pressure relief.
I see 2 issues with your valving setup, it needs a reservoir to allow at least 2 gallons of oil to be in reserve (supply to pump), and not just what is in the cylinders. This will allow substantial cooling of the fluid. On the the relief issue I would buy a pressure regulator adjustable between 0 and 1500 psi with a flow rating of 6 gpm or more. It should be plumbed in the lines after the valves that go to the loader. It is piped with A "T" in each line (pressure and return) with the valve in between. JimN
