If it fails to spin like a motor when voltage is applied from its ARM post to case frame (ground), I suspect the Armature might be bad, although other field or brush problems may still be at fault !!
Does it show any burned places or melted solder where its windings meet the commutator?????
Any classic electrical burned smells???
There should NOT be continuity from any commutator segment to the steel center shaft or any other metal CUZ THATS A SHORTED ARMATURE WINDING. An ohm meter or DC continuity tester can easily test for that.
With the armature removed the 2 field windings in series as measured form ARM post to FLD post should be in the vicinity of 3 to 6 ohms, depends on what genny and if its 6 or 12 volt. INSURE the splice is good where the 2 field windings join together AND INSURE its NOT shorted to frame somewhere.
There should be infinite ohms OPEN circuit from ARM or FLD to case frame (armature removed) cuz if not one or both the fields or their splice is shorted.
The ARM post must be connected internally to BOTH the non grounded brush and the beginning of the first Field winding, the first field splices to second (be sure it is and NOT grounded), then out to FLD post.
Brushes and brush holds down springys all gotta be okay
Get it fixed, Im runnin outa smarts n ideas here lol
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
