Then the pressure regulator is in the circuit. It needs to be checked for operation when a new gear is installed. Check all three gears in that system for chipped or damaged teeth. replace any suspect gears (maybe all of them) Sometimes gears go bad, or have some other object get between them and wedge them into bits. I would check the pressure regulator, then put it back together. JimN
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
