1586 questions
Posted by moline_guy on June 05, 2009 at 23:10:15 from (66.231.24.111):
third party image
Bought this 1586 last month and today was the first time i was using the 3pt and hydraulics at the same time. When i had the 3pt lever all the way ahead (3pt down) the hydraulic outlets dont work. Is this suppose to be or do i have problems. As soon as you move the 3pt lever back a bit everything works.
One other thing, when i change out the rear end oil do all the plugs need to be removed or can just the center one under the drawbar and the one under the speed trans drain it out. I noticed there are two plugs under the bull gears, should these two be removed to drain?
Thanks for any help.
