Posted by D Slater on June 07, 2009 at 06:34:22 from (72.65.130.133):
In Reply to: Farmall Super M Head posted by IH-Mitch on June 06, 2009 at 18:57:05:
If its a gasoline fuel head look for a casting # on top of head. Some late 52 M and W6 tractors came with the same head as SM,SW6, SW6TA and SMTA came with. Numbers 8060 DC or 8574 DB. later head numbers 8060 DD and 8574 DC would be good. Most other M heads with a lower ending letter suffix will work. Number series tractors gas heads for 400 and 450 will also work, but require a top end ventilation change, most times are higher priced and will raise the compression. Almost all heads from M to 450 will bolt on and can be made to work, performance of tractor will not be the same for some of them. When looking for a head its best to go by the casting numbers, I would guess over half the tractors mentioned above don"t have the same heads that came on them. If your SM does I agree with James, if the crack is in a repairable place it may be best to have it repaired at a place with a good reputation unless you find a uncracked one for less.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
