Re: M and Super M gear speeds
Posted by Bob M on June 07, 2009 at 12:28:16 from (74.74.133.11):
In Reply to: M and Super M gear speeds posted by Farrell(Utah) on June 07, 2009 at 08:51:07:
Only 1st gear is the same for the M and Super M. Super M's higher gears (and reverse) are all faster.
Published Super M ground speeds for 13.6 x 38 tires:
1st - 2-5/8
2nd - 3-3/4
3rd - 5
4th - 6-3/4
5th - 16 - 3/4
Naturally with 14.9 tires gives speeds a bit higher.
FWIW a hand-held GPS shows my Super M (14.9 tires) runs 19.1 mph on a flat road in 5th.
