Re: 756 Hydraulic Issues
Posted by MN Scott on June 07, 2009 at 21:14:18 from (206.9.216.69):
In Reply to: Re: 756 Hydraulic Issues posted by pete 23 on June 07, 2009 at 16:59:50:
Yes, the driven in one. I installed it lip in then bolted in pump then installed tube from filter side into pump. The pump is the closed in type, Cessna, no plate. When I had it on the bench, I covered the suction port with my palm and spun the gear. It sucked in my palm. I realize this means little but at least a seal is not completely gone. I'am going to get some more oil tomorrow to cover the suction pipe just to rule that out. I guess if that dose'nt work I'll replace the pump. If that does not work I'am at a loss as to were the air could be comming from, its really a simple system.
