Re: Replacing Rings in a 46 H
Posted by Nebraska Kirk on June 08, 2009 at 11:07:50 from (207.91.4.208):
In Reply to: Replacing Rings in a 46 H posted by Illinois Farmall on June 08, 2009 at 06:14:29:
It is a fairly involved process, you have to remove the head and oil pan, then remove rod caps from below, push piston/rod assembly out the top, then you can remove the old rings and install new ones, hone cylinders and then reinstall. HOWEVER, the cylinder sleeves may be worn enough that new rings would not fix the problem and you would need to rebuild the engine.
