If it was timing, it wouldn't run that well for that long, so it's something else. Aggravatin' part is that it's apt to turn out to be somethin' really simple.
Check for an air leak when it starts to act up by spraying carb or brake cleaner near where the manifold joins the head and down by where the carb mounts to the manifold, as well. If that's a problem, I'd sooner suspect the upper end opening up a gap as the manifold starts to heat up.
You didn't mention your ignition condenser. That'd be worth checking out. What I hear, about one of of three or four is bad right out of the box.
On the oddball list, are both ends of your coil wire seated firmly in the cap and coil? That one bridge/connection can shut the whole works down.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
