Re: Slow cranking
Posted by Hugh MacKay on June 08, 2009 at 13:25:02 from (216.208.58.170):
In Reply to: Re: Slow cranking posted by dougie94 on June 08, 2009 at 10:36:00:
dougie: Don't bet all your wealth on that, the others all make good points. Another item I might add at this point, go to cast for your ground. There has been more troubles with that ground strap bolted to top of dash or battery box, than a dog has flees.
